Satchwell DWT0001 or DWT1701 replacement
  • Satchwell DWT0001 or DWT1701 replacement
  • DavidChild
    DavidChild
‎2018-09-06 02:29 PM
Last Updated: Sisko DavidChild Sisko ‎2019-08-22 03:10 AM
Replacement for Satchwell DWT0001 or DWT1701 by the STP660 Immersion Temperature Sensor due to obsolescence.
Field Devices
  • DWT1701
  • DWT0001
Obsolescence of Satchwell DWT0001 and DWT1701 Immersion Temperature Sensor.
The STP660 Immersion Temperature Sensor is the replacement for the DWT0001 and older DWT1701
The STP660 provides the same functionality as the Satchwell DWT0001 and DWT1701, differing only in its appearance, dimensions and terminal identification.
A pocket or well is also required and is sold separately.
  • 9121066000 - Brass
  • 9121060000 - Stainless Steel
N.B. In the case of a DWT0001 and only the sensor part is required, then the STP660 will fit into the existing pocket (and adaptor).
or In the case of a DWT1701 and the sensor part is only required, then a pocket adaptor 9121058000 is needed.
  • Field Devices
Tags (2)
  • 3851
  • DavidChild19
0% helpful (0/1)
