Sample PE program to control access by forklift operator to storage cage gate
  • Sample PE program to control access by forklift operator to storage cage gate
  • RandyDavis
    RandyDavis
  • AbeMeran
    AbeMeran
Captain AbeMeran Captain
‎2022-08-10 08:13 AM
on ‎2022-08-10 08:13 AM
Need sample PE program for control of access to a storage cage gate by forklift operators where the gate is required to stay open (up) until the forklift operator cards at the reader a second time on his/her way out of the cage.
Andover Continuum
  • Continuum Net Controller II
  • Continuum ACX 2 Controller
  • Continuum ACX 4 Controller
Continuum PE programming guidelines
This sample program was provided as proof of concept only and not intended as a complete solution to the use case.
Object : StorageCageControl
 Type : InfinityProgram
 LastChange : 1/29/2020 11:29:14 AM
 DeviceId : PSS\ACX2.10
 Alias : StorageCageContr
 CreateTime : 1/29/2020 9:59:56 AM
 CreatedBy : Root\Acc
 TimeLocked : 1/29/2020 11:29:14 AM
 InstanceId : 7003/7002
 ByteCode :
'SAMPLE program for controlling access to a Storage Cage gate 1/29/2020 AM
'Program is LOOPING/AUTOSTART
'DESCRIPTION
'On valid access to the cage by forklift operator, program will unlock the gate using the
' PermanentUnlock property to keep it unlocked until the forklift operator indicates the gate
'can be closed by presenting his/her card at the card reader.
'REQUIREMENTS
'1. ACX2 or NC2 controller only, program wont work in NC1 or old ACX7xx as they don't support the PermanentUnlock flag
'2. Set the StrikeTime attribute of the door controlling the gate to ZERO
'3. Create GateLeftOpenALM InfinityNumeric, and attach to an alarm (Optional)
Numeric CloseTimeOut
Line Init
  CloseTimeOut = 15 'Notify gate may have been left open after CloseTimeOut minutes.
  Goto WaitToOpen
Line WaitToOpen
  GateLeftOpenALM = False
  If CageGate ValidAccess then
    CageGate PermanentUnlock = True
    Goto WaitToClose
  Endif
Line WaitToClose
    CageGate PermanentUnlock = False
    Goto WaitToOpen
  Endif
  If TM >= CloseTimeOut then GateLeftOpenALM = True 'Gate may have been accidentally  left open
Line E
'oops, runtime error, wait a bit then try again
  If TS > 30 then Goto Init
 EndByteCode
 Status : Active
EndObject
Tags (5)
  • AbeMeran22
  • access
  • control
  • pe
  • program
