Sample PE program for synchronizing controllers time across networks and time zones
  • Sample PE program for synchronizing controllers time across networks and time zones
  • RandyDavis
    RandyDavis
  • AbeMeran
    AbeMeran
Captain AbeMeran Captain
‎2021-01-22 07:51 AM
on ‎2021-01-22 07:51 AM
Synchronizing time across many networks and multiple time zones
Andover Continuum
Continuum Cyberstation
Guidelines for implementing an efficient yet compact Cyberstation PE program to synchronize time on large installations consisting of many Continuum networks across multiple time zones.
The solution presented here requires that in each network the time master (controller with the lowest ACCNetId) is identified by setting its description to PTM. (Primary Time Master)
It is also recommended that the controller with the second-lowest ID is identified as the STM.
Obviously, the program itself could identify the time master for each Network but doing this outside of the program makes for a simpler, more robust implementation.
To implement the solution, simply create a program in one of the Continuum Cyberstations and insert the code provided below.
Configured the HOUR System Variable in the Cyberstation to trigger the program.
The program, as written, will sync the time once a day at 3:00 AM
There is a local variable (Verbose) that controls the level of information the program prints to the message window, recommends this be set to print everything when the implementation is first put in place to ensure it is operating as expected, then print only errors afterward.
'This program synchronizes time between Cyberstation and controllers across Networks and time zones.
'Program is triggered by the HOUR system variable
'SETUP
'In each network, the controller with the lowest ACCNetID must be identified as the Primary Time Master
' by setting its description to PTM
'Optionally, the controller with the second-lowest ACCNetID can be identified as the Secondary Time Master
' by setting its description to STM
'v1.0 SE PSS 1010 1011 1110 - FOR PROOF OF CONCEPT PURPOSE ONLY
Object theCX
Object theNetwork
Object theWS 'The Workstation where the program is running
Number WS_UTCOffset 'The UTC Offset of theWS
Number syncDone
Number Verbose 'Prints to theWS message window. Set to 1 to print errors only, set to 2 to print synchronization information.
Line INIT
  If Hour <> 3 then Stop  'sync time once a day at 3am
  theWS = CurWorkstation() 'get the name of the Cyberstation where the program is running
  WS_UTCOffset = getname("root\" ; theWS Alias ; " UTCOffset") 'and theWS UTC Offset
  Verbose = 0 'default to silent operation
  Goto SynchronizeTime
Line SynchronizeTime
  If OpenList("Network", theNetwork) is Success then
    While GetObject(theNetwork) is Success 'for each Network...
      If Verbose = 2 then Print "Syncronizing time on NETWORK: " ; theNetwork Alias
      If OpenList("InfinityController", theCX, theNetwork) is Success then
        While GetObject(theCX) is Success 'for each CX controller in the network...
          syncDone = False 'reset the sync done flag
'Print theCX alias REMOVE COMMENT TO PRINT CX NAME, HELPFUL WHEN DEBUGGING THIS PROGRAM
          If theCX Description = "PTM" and theCX CommStatus = OnLine then 'is this controller the time master and if so, is it ONLINE?
            If Verbose = 2 then Print "Time syncronized on NETWORK: " ; theNetwork Alias ; ", CONTROLLER: " ; theCX Alias ; " (Primary Time Master)"
            getname(theNetwork Alias ; "\" ; theCX Alias ; "\Date") = Date + ((theNetwork UTCOffset - Cyber221 UTCOffset) * 60) 'synchronize its time
            syncDone = True 'we're done with this network...
            Break '...so break out of the inner while loop
          Endif
          If theCX Description = "STM" and theCX CommStatus = OffLine then 'look for a secondary time master if primary not online
            If Verbose = 2 then Print "Time syncronized on NETWORK: " ; theNetwork Alias ; ", CONTROLLER: " ; theCX Alias ; " Secondary Time Master"
          Endif
        Endwhile
        CloseList(theCX)
        If syncDone = False and Verbose > 0 then Print "No time master found online for NETWORK: " ; theNetwork Alias ; "," ; Date
      Else
        If Verbose > 0 then Print "ERROR, can't open Controller list " ; Date
      Endif
    Endwhile
    CloseList(theNetwork)
  Else
    If Verbose > 0 then Print "ERROR, can't open Network list " ; Date
  Endif
  Stop
Line E
  If Verbose > 0 then Print "Program hit ERROR line, " ; Date
  Stop
Tags (8)
  • AbeMeran21
  • network
  • sync
  • synchronization
  • time
  • time zones
  • utc
  • UTCOffet
