Sample PE Program that reads/writes files
  • Sample PE Program that reads/writes files
  • AbeMeran
    AbeMeran
‎2018-09-11 03:06 PM
Last Updated: Administrator DavidFisher Administrator ‎2019-07-22 08:15 AM
How to read and write from/to files using PE
Andover Continuum
  • CyberStation
  • Plain English
Site needed a CSV report of personnel accessing the building that included access event information such as time stamp, door, area, card number BUT also data such as employee number etc., a simple list view could not be used since list views can only show data from ONE table in the ContinuumDB.
Sample CyberStation program that reads/writes from/to file and aggregate data from different tables in the ContinuumDB
IMPORTANT:
PE Program is provided as a sample proof of concept ONLY and it is not to be taken as a complete working solution.
REQUIREMENTS:
Create STRINGS ReportEventsPath and T_A_Path in the CyberStation where the program will run and set to the path to the input and output files respectively, the input file must exist, the output file will be automatically created if it doesn’t exist.
PROGRAM CODE:
'This Cyberstation program takes as an input a CSV file generated from an Access Event list
'and creates a second file with the EMPLOYEE NUMBER added.
'Program is FALL-THRU and NOT autostart
'IMPORTANT
'The Input file MUST be formatted like this...
'AccessEvent
'PersonId,TimeStamp,CardNumber,AreaId
'Root\MyPersonnel\Meran_Abe,3/31/2014 10:16:11 PM,3540,Root\MyAreas\Area1
File inputFILE, outputFILE
String 132 DATALINE, RESULT, theEMPLOYEE, empNUMBER, localSTR
Numeric CHARSREAD, CHARSWRITTEN, OK, RECORDLINE
Numeric DEBUG_FLAG
Line INITIALIZE
  DEBUG_FLAG = 0 'SET THIS TO 1 TO HAVE PROGRAM PRINT DEBUG INFO
Line OPENING
  RESULT = ""
  RECORDLINE = 0
  CHARSREAD = 0
  If OpenFile(ReportEventsPath, ReadOnly, inputFILE) = Failure then 'OPEN THE INPUT FILE TO READ FROM
    RESULT = "COULD NOT OPEN inputFILE FILE"
    Goto FAILING
  Endif
  If OpenFile(T_A_Path, WriteOnly, outputFILE) = Failure then 'OPEN THE OUTPUT FILE TO WRITE TO
    RESULT = "COULD NOT OPEN outputFILE FILE"
    Goto FAILING
  Else
    Goto COPYING
  Endif
Line COPYING
  RECORDLINE = RECORDLINE + 1
  If DEBUG_FLAG then Print "Record line = " ; RECORDLINE
  If RECORDLINE = 1 then
    OK = ReadFile(inputFILE, DATALINE, 132, CHARSREAD, "|10") 'READ FIRST LINE FROM THE INPUT FILE UP TO THE LF
  Else
    OK = ReadFile(inputFILE, DATALINE, 132, CHARSREAD, "|13") 'READ ONE LINE FROM THE INPUT FILE UP TO THE CR
  Endif
  If OK = Failure then
    RESULT = "COULD NOT READ FILE"
    Goto FAILING
  Else
    If DEBUG_FLAG then Print "Read..." ; DATALINE
    If OK = Eof then
      RESULT = "END OF FILE"
      Goto CLOSING
    Endif
  Endif
'INSERT THE EMPLOYEE NUMBER
  If RECORDLINE = 2 then empNUMBER = "EmpNumber" 'MODIFY THE HEADER WITH THE NAME OF THE FIELD(S) WE ARE ADDING
  If RECORDLINE > 2 then
    theEMPLOYEE = (left(DATALINE, search(DATALINE, ",")))
    theEMPLOYEE = (left(theEMPLOYEE, (search(theEMPLOYEE, ",") - 1))) 'FOR EACH LINE IN THE INPUT FILE GET THE PATH TO THE PERSONNEL OBJECT
    Print getname(theEMPLOYEE ; " EmpNumber") to empNUMBER 'AND GET THE EMPLOYEE NUMBER
  Endif
'WRITE THE LINE WITH THE ADDED NEW FIELD(S) TO THE OUTPUT FILE
    Print DATALINE ; chr(10) to localSTR
  Else
    Print DATALINE ; "," ; empNUMBER ; chr(10) to localSTR
  Endif
  OK = WriteFile(outputFILE, localSTR, 132, CHARSWRITTEN)
    RESULT = "COULD NOT WRITE FILE"
    Goto FAILING
  Else
    If DEBUG_FLAG then
      Print "Wrote..." ; localSTR
    Print "CHARSWRITTEN=" ; CHARSWRITTEN
  Endif
'POINT TO THE NEXT LINE IN THE FILES
    If PositionFile(inputFILE, 1, FileCurrent) = Failure then Goto CLOSING 'ADVANCE PAST THE LF
  Else
    If PositionFile(inputFILE, 2, FileCurrent) = Failure then Goto CLOSING 'ADVANCE PAST THE CR and LF
  Endif
  If PositionFile(outputFILE, 0, FileCurrent) = Failure then Goto CLOSING 'WRITE AT THE CURRENT FILE LOCATION
    Goto COPYING 'GO DO THE NEXT LINE
  Endif
Line FAILING 'SOMETHING WENT WRONG
  If DEBUG_FLAG then Print RESULT
  Goto CLOSING
Line CLOSING
'CLOSE THE FILES
  If CloseFile(inputFILE) is Failure then RESULT = "COULD NOT CLOSE FILE"
  If CloseFile(outputFILE) is Failure then RESULT = "COULD NOT CLOSE FILE"
  If DEBUG_FLAG then PEDebug = PEDebug + 1 'IF DEBUGGING INCREMENTED PEDebug MEANS NO ERRORS
  Stop
Line E 'HANDLE RUNTIME ERROR
  If DEBUG_FLAG then
    Print RESULT
    PEDebug = 666
  Endif
  Stop
After the program runs if the input file looks like:
'AccessEvent
The output file will be:
'AccessEvent,
'PersonId,TimeStamp,CardNumber,AreaId,EmpNumber,
'Root\MyPersonnel\Meran_Abe,3/31/2014 10:16:11 PM,3540,Root\MyAreas\Area1,12345
  • 16996
0% helpful (0/1)
This is a heading
