STR800 thermistor accuracy.
  • STR800 thermistor accuracy.
  • Leo_Tantalo
    Leo_Tantalo
‎2018-09-06 10:24 AM
The STR800 sensor is a replacement for the TSMN-57011-850.  What is the thermistor's accuracy?  The datasheet (F-27739) does not provide this information.
Temperature sensors
Missing data in the spec sheet
Sensing Element:  Thermistor resistance, 10,000 ohms at 77°F (25°C) shunted with an 11K ohms 0.1% resistor.
Within operating temperature limits of 32 to 158°F (0 to 70°C):
  • Error ±0.36°F (0.2°C) maximum
  • Drift/Year 0.045°F (0.025°C) maximum
Over Operating Temperature Limits:
  • Error ±0.76°F (0.42°C) maximum
  • Drift/Year 0.09°F (0.05°C) maximum
Labels (2)
  • Field Devices
  • TAC IA Series
  • 13221
