STR150 used with TAC Xenta 102B
  • STR150 used with TAC Xenta 102B
  • MikaelKrantz
    MikaelKrantz
‎2018-09-06 09:04 AM
Last Updated: Administrator DavidFisher Administrator ‎2019-06-17 01:55 PM
Is it possible to use the TAC Xenta 102B device with room unit STR150?
TAC Vista
  • STR150
    TAC Xenta 102B
It is possible to use STR150 together with the TAC Xenta 102B device with system program 1.20 or higher.
To use an STR-150 on a TAC Xenta 102-B controller, set nciAppOption bit 14.
Tags (2)
  • 17783
  • xenta102b
