STR-350 will not send a service pin message
  • STR-350 will not send a service pin message
‎2018-09-06 03:05 PM
STR-350 will not send a service pin message.
STR-350
LNS Database
If the STR-350 has been commissioned previously then deleted from the LonMaker database it will not send out a service pin message until taking the steps below.
Manually enter the Neuron ID of the STR-350 and commission it into the network. This will restore the service pin functionality.
Tags (2)
  • 2018
  • thermostat
