STR-250 displays temperature but unable to control any changes on Xenta 102-AX
  • STR-250 displays temperature but unable to control any changes on Xenta 102-AX
  • SESA116857
    SESA116857
‎2018-09-06 01:21 PM
STR-250 is connected to a Xenta 102-AX and displays the space temperature but any attempts to modify the setpoint or override the occupancy is unsuccessful.
STR-250
Xenta 102-AX
The wiring between the Xenta 102-AX and the STR-250 must comply with the installation instructions:
18-24 AWG three conductor cable or shielded, twisted pair (Belden 9184 equivalent) 30 m (100ft) maximum from the controller. Total capacitance may not exceed 4000 pF.
Ensure that the cabling matches the documented requirements.
Note: with lower gauge wiring the resistance increases and you might need to reduce the distance between the Xenta 102-AX and the STR-250 thermostat to ensure proper communication.
  • 6058
