STP sensor series mounting instructions for straight pipe
  • STP sensor series mounting instructions for straight pipe
  • SESA150559
    SESA150559
‎2018-09-11 12:28 AM
The documentation only describes mounting on curved pipe.
STP100
STP101
STP120
STP200
STP201
STP300
STP501
STP600
In some applications, mounting the sensor on a straight pipe is necessary
A description drawing is available here.
The installation should be beveled against flow direction and the diameter should not be bigger than half of the diameter of the pipe.
  • Field Devices
  • 12347
