STD300 flange material
  • STD300 flange material
  • SESA150559
    SESA150559
‎2018-09-06 12:50 PM
There is a difference between the STD300 sensor flanges compared to the ones pictured in the data sheets.
STD300
Design differences between picture on data sheet and actual sensor.
There was a slight design change on the sealing flange a while ago where the metal piece was replaced by a plastic flange. This to get a more flexible surface to the duct, and therefore a better seal.
  • Field Devices
  • 7051
