STC contact temperature transmitter application
  • STC contact temperature transmitter application
  • SESA150559
    SESA150559
‎2018-09-06 10:37 AM
The STC series transmitter is delivered with a pipe clamp designed for maximum 100mm (4") pipe diameter. Is there any other solution if pipe diameter is larger than 100mm/4"?
STC100
STC101
STC200
STC201
STC110
STC120
STC300
STC600
Included pipe clamp does not fit larger pipe size applications.
If the application requires the transmitter to fit pipe with bigger outer diameter than 100mm/4", the included pipe clamp can be replaced with a bigger clamp purchased locally at the hardware store or similar.
  • Field Devices
Tags (6)
  • 12642
  • clip
  • hose
  • hoseclip
  • jubilee
  • sensor
