SQL server uses up my harddrive, templog.ldf is several Gb.
  • SQL server uses up my harddrive, templog.ldf is several Gb.
  • Per_Sjöstrand
    Per_Sjöstrand
‎2018-09-06 02:26 PM
SQL Express 2005
In SQL there are some system databases used by the server when administrating data within the server.
If you run SQL server for several months without restart, templog.ldf will grow
By adding growth restrictions for tempdb this will not be a problem. Most sites do not have these problems as updates, etc., usually force restarts of the computer.
  • 3947
