SQL account used by I/NET Seven
  • SQL account used by I/NET Seven
  • Derrick_Ratliff
    Derrick_Ratliff
‎2018-09-06 12:45 PM
Equalization Failure.  Unable to promote remote or equalized client
I/NET Seven
I/NET Seven creates and used the user account INETSEVEN within SQL. This account is given full admin rights during installation and any change in these rights will prevent I/NET from correctly using SQL.  The password for this account is encrypted and is specific to each I/NET installation so this password cannot be provided.
Do not change settings on this account.  If modifications are made you will need to uninstall and re-install I/NET Seven.
  • TAC INET
  • 7177
