SQL Server errors when installing Cyberstation.
  • SQL Server errors when installing Cyberstation.
  • sesa116832
    sesa116832
‎2018-09-06 12:30 PM
Installing Cyberstation on a Standalone workstation results in SQL Server errors.
Cyberstation Standalone.
Installing Cyberstation on a StandAlone workstation returns the error "Another version of SQL is installed." The Standalone had Windows 7 installed.
On the Windows 7 workstation, select  Start  > All Programs > System Tools > System Restore.   Select a restore point that pre-dates the Cyberstation install. Once the system has been successfully returned to that restore point, reinstall Cyberstation.
  • 7639
