SQL Equalization Failure on Non-English Systems
  • SQL Equalization Failure on Non-English Systems
  • Derrick_Ratliff
    Derrick_Ratliff
‎2018-09-06 01:46 PM
I/NET
File Equalization
Client Computer
There is a collation mismatch that was caused during the SQL installation.
  1. Go to the Client PC
  2. Demote the client PC to Standalone
  3. Create a Temporary Folder on the C Drive, for example C:\Equalization
  4. Run the SQL Express install file
  5. Wait for the installation shell to start, but do not hit NEXT
  6. Browse to your C: Drive and look for a temporary folder with a current time stamp. This will likely have a name made of random numbers and letters
  7. Open this folder and copy the contents to your temporary folder. You may need to copy each file manual as a file beginning in $ will not copy.  You do not need this file.
  8. Cancel out of the SQL Express installation program
  9. Open the Command Prompt
  10. Browse to the temporary folder you copied files to
  11. Type in the following exactly, but replace *** with the sa password for your system
    This doesn't make any sense to me, any time the text on a link passes the end of the line the line is supposed to wrap to the next line
    setup.exe /QUIET /ACTION=REBUILDDATABASE /INSTANCENAME=MSSQLSERVER /SAPWD=***
    /SQLSYSADMINACCOUNTS=Administrator /SQLCOLLATION=SQL_Latin1_General_CP1_CI_AS
  12. This will run a limited version of the SQL installation.  Follow the instructions as prompted
  13. Re-promote the PC to Equalized client.
  14. Manually delete the temporary folder you created in step 3
  • TAC INET
  • 5291
