SQL 2005 installation takes a long time
  • SQL 2005 installation takes a long time
  • ScottLeedberg
    ScottLeedberg
‎2018-09-07 02:53 AM
Why does the install for SQL 2005 take so long?
SQL 2005
Under certain conditions during the SQL 2005 installation process it could look like the installation hangs at "Setting File Security". This is a known problem with Microsoft.
The workaround is to disconnect machine from the network and then the install should go through quickly.
A cumulative hotfix is available from Microsoft that will address this issue. It can be found at https://support.microsoft.com
  • 2903
