SPD310/SPD360 changing airflow direction
  • SPD310/SPD360 changing airflow direction
  • SESA150559
    SESA150559
‎2018-09-06 02:05 PM
If airflow direction is reversed in duct from f.ex. 100 Pa to -100 Pa, will the SPD310/SPD360 break?
  • SPD310
  • SPD360
Reversing airflow direction in duct.
It will not break.
If the "sym" jumper setting is changed when airflow direction is changed (reversed), it will read the value correctly.
  • Field Devices
  • 4701
