SP-C or SP-C-Web Battery Test
  • SP-C or SP-C-Web Battery Test
  • DavidChild
    DavidChild
  • David_Kendrick
    David_Kendrick
Admiral David_Kendrick Admiral
‎2020-09-11 06:41 AM
Last Updated: Sisko DavidChild Sisko ‎2020-09-11 06:41 AM
Is it possible to trigger a manual Battery Test in a SP-C or SP-C-Web?
Security Expert
  • SP-C
  • SP-C-Web
The SP-C Web Security Expert - Programming - Reference Guide refers to indication of when the SP-C-Web passes or fails its Dynamic Battery Test, but what if a user wishes to manually perform or trigger such a battery test.BatteryTest.png
The Dynamic Battery Test is a purely automated process and cannot be manually forced or triggered, however these tests are performed every ten minutes when mains power is present.
  • EcoStruxure Security Expert
  • DavidKendrick20
