SNVTs supported in Xenta server 5.1.6
  • SNVTs supported in Xenta server 5.1.6
  • sesa177673
    sesa177673
‎2018-09-06 01:09 PM
Are the following SNVTs supported in Vista 5.1.6?
  • SNVT_Amp_ac
  • SNVT_Count_32
  • SNVT_Volt_ac
Xenta X5XX, X7XX, X9XX with firmware 5.1.6
The SNVTs  SNVT_Amp_ac, SNVT_Count_32 and SNVT_Volt_ac are not included in the Xenta 5.1.6 firmware. They will be included in 5.1.7. There is however a workaround available in 5.1.6
  1. Locate the SNVTtype.def file in the Xenta server.
    Connect to the Xenta server using an FTP client and locate the SNVTtype.def file under configdb/Lon/SNVTTYPE.def.
  2. Copy the file to your PC and make a backup copy
  3. Edit the file with a suitable text editor (notepad, notepad2 etc)
    -Locate the SNVT_amp definition
    -Add the following lines after SNVT_amp definition (see screenshot below):
    amp_ac
    139
    2
    1
    INTEGER,,2,0,65535,1,0
  4. Repeat the process with the other 2 SNVTs
    - SNVT_count_32:
    Add the following lines after SNVT_count definition:
    count_32
    183
    4
    1
    INTEGER,,7,-2147483648,2147483647,1,0,raw
    - SNVT_volt_ac:
    Add the following lines after SNVT_volt definition:
    volt_ac
    138
    2
    1
  5. Replace the SNVTType.def file in the Xenta server using the FTP client.
  • 6552
