SNVT_press_p will not display correctly in Imperial units on a TGML graphic on a Xenta Server
  • SNVT_press_p will not display correctly in Imperial units on a TGML graphic on a Xenta Server
  • SESA116857
    SESA116857
‎2018-09-07 01:32 AM
Last Updated: Administrator DavidFisher Administrator ‎2020-10-29 07:31 AM
TAC Vista
  • Xenta Servers
  • Xenta 511, 527, 711, 731
There is a bug with the TGML graphic editor that causes a SNVT_press_p to only display in the SI units of pascals.
Until this issue is corrected you can manually convert the value on the graphic page using a JavaScript.
This Pascal to H2O Snippet can be used to modify a numeric or text presentation object.
Pascal to H20.zip
  • 3219
