SNVT is not propagated from TAC Xenta 121-FC
  • SNVT is not propagated from TAC Xenta 121-FC
  • MikaelKrantz
    MikaelKrantz
‎2018-09-06 10:27 AM
Why is not nvoSpaceCO2 propagated in TAC Xenta 121-FC?
TAC Vista
TAC Xenta 121-FC
You must have a binding for the SNVT to be propagated.
Also, not all SNVT are sent by heartbeat (please note that the tooltip text in ZBuilder was corrected in version 5.1.7).
Make sure that you have a binding from the actual SNVT.
Make sure that the value is changed more than the actual setting for propagation.
  • 13084
