SHD100: Using 24V AC power supply and 4-20mA output signal
  • SHD100: Using 24V AC power supply and 4-20mA output signal
  • SESA150559
    SESA150559
‎2018-09-06 12:18 PM
The data sheet only lists AC power supply as an option when using the 0-10V output signal
SHD100 006902320
SHD100-T 006902330
Sensor configuration options.
For a transmitter the operating (normal) current is at once the measuring signal. If a rectified output is requested this means that DC voltage as supply voltage is required.
  • Field Devices
  • 8005
