SHD100 / SHR100 humidity sensor deterioration over time?
  • SHD100 / SHR100 humidity sensor deterioration over time?
  • SESA150559
    SESA150559
‎2018-09-06 10:08 AM
Does the operation/accuracy of the 4-20mA Humidity sensor deteriorate over time?
SHR100
SHD100
Accuracy deterioration over time?
The documented deterioration/inaccuracy after 5 years is < ± 3% RH. For more details, see the data sheet for each sensor model respectively.
  • Field Devices
  • 14131
