SHD100/SHD101 Humidity Sensor - Maximum Air Velocity
  • SHD100/SHD101 Humidity Sensor - Maximum Air Velocity
  • SESA150559
    SESA150559
‎2018-09-06 09:55 AM
What is the Maximum Air Velocity that can pass across a SHD100/SHD101 Humidity Sensor?
SHD100
SHD101
Some applications has a high velocity that needs to be measured.
The flow rate is only critical at higher humidity.
Furthermore, it also depends on the porosity of the filter.
At humidity less than 95% r.H. up to an air velocity to 15 m/s there should be no problem.
  • Field Devices
  • 14840
