SECURITY EXPERT: Turned off the backup function to not back up a server but still backing up the event database.
  • SECURITY EXPERT: Turned off the backup function to not back up a server but still backing up the event database.
  • RandyDavis
    RandyDavis
  • Sampath_Konda
    Sampath_Konda
Commander Sampath_Konda Commander
‎2019-10-16 10:54 AM
Last Updated: Guinan RandyDavis Guinan ‎2019-10-16 10:55 AM
Turned off the "Backup Main Database Every Night" to stop back up of a server but it is still backing up the event database.
Security Expert
Security Expert Server
Even though the "Backup Main Database Every Night" option is turned off, the "Event Database"->"Generate Differential Events Backup" is running ever night.
Log on to the Security Expert System then go to Global->General-> under the events tab. Uncheck/remove the "Generate Differential Events Backup" option along with "Backup Main Database Every Night".  The event's backup will stop.
Generate Differential Events BackupGenerate Differential Events Backup
Main and Events DB backup SettingsMain and Events DB backup Settings
  • EcoStruxure Security Expert
  • SampathKonda19
