SE7xxxx Room Controller Password
  • SE7xxxx Room Controller Password
  • DavidChild
    DavidChild
Sisko DavidChild Sisko
‎2021-05-27 01:23 AM
on ‎2021-05-27 01:23 AM
Unable to access the SE7xxx Room Controller configuration parameters menu - displays an error code.
EcoStruxure Building Expert, Field Devices
  • SE7xxx Room controller
  • SE7000 Series
  • Ex. Viconics branding VT7000 Series
The display shows an error code when used, this is indicating a password is required, an example of the error code may be 977 or 996.
Contact your region's Customer Care Center for a temporary password.
The error code which is unique to that controller will be required by the Customer Care Center to calculate the temporary password.
Note for PSS; Check Internal article.
Labels (2)
  • EcoStruxure Building Expert
  • Field Devices
  • DavidChild21
0% helpful (0/1)
