S-E Forta M700 Actuator unable to be mounted on S-E VGS211F Valve Body due to absence of S-E VGS211F Valve Body Spindle Adaptor.
  • S-E Forta M700 Actuator unable to be mounted on S-E VGS211F Valve Body due to absence of S-E VGS211F Valve Body Spindle Adapt...
‎2018-09-06 02:37 PM
S-E Forta M700 Actuator unable to be mounted on S-E VGS211F Valve Body .
S-E Forta M700 Actuator mounted on S-E VGS211F Valve Body
1.  Install S-E VGS211F Valve Body Spindle Adaptor prior to installation of S-E Forta M700 Actuator.
The S-E VGS211F Valve Body is supplied with a Valve Spindle Adaptor.
The Adaptor is illustrated in the S-E Forta M700 Installation Instruction (OFL – 4340 – 001).
It is particularly important to ensure that this Adaptor is fitted to the Valve Spindle, as its absence will prevent the M700 Actuator from being mechanically connected to the Valve Body Spindle.
  • Field Devices
  • 3437
