Continue
  • My Subscriptions
  • Events
Running a Niagara Station on a Workbench without PC Administrative Privileges
  • Running a Niagara Station on a Workbench without PC Administrative Privileges
  • RandyDavis
    RandyDavis
RandyDavis Champion
‎2025-07-24 10:29 AM
on ‎2025-07-24 10:29 AM
Access to the Platform on a PC without administrative privileges is, by default, not allowed.
TAC IA Series
I/A Series N4 /AX Workbench
Default Platform access is restricted to persons logging on to the PC with administrative privileges
To run a station on a Workbench, you must open the Platform to install and start the station.
  1. Consult with your IT department about getting a temporary local admin account or have them assist you with this process.
  2. Start the daemon you wish to run the station in
  3. Open Workbench of the running daemon
  4. Open the Platform
  6. Now you can open the Platform and run stations without having administrative rights on your PC.
        Notes:
    • This must be done for each version of Niagara Workbench
    • If you have a Schneider Electric laptop with CyberArk EPM installed, obtain a CyberArk JIT for administrative privileges from SE Support.
    • If you have a Schneider Electric laptop, when logging in to the "Update Authentication" in the Platform, use your SESA login.
  • TAC IA Series
  • RandyDavis25
100% helpful (3/3)
