Running Forta series actuators on 24VDC
  • Running Forta series actuators on 24VDC
  • Gary
    Gary
  • SESA150559
    SESA150559
‎2018-09-06 12:58 PM
Is it possible to run a Forta series actuator on 24VDC?
TAC Forta series actuators:
M300
M310
M400
M750
M800
M1500
M3000
The TAC Forta series actuators older documentation suggests it can only be run on 24VAC only.
The TAC Forta series actuators can run on 24VAC +/- 25% or 24Vdc +/- 10%.
For more specific details on tolerances, please see the data sheet for each product.
  • Field Devices
  • 6778
