Running Bomgar Remote Support Client from Linux
  • Running Bomgar Remote Support Client from Linux
  • David_Purser
    David_Purser
Picard David_Purser Picard
‎2023-03-27 09:13 AM
on ‎2023-03-27 09:13 AM
Running Bomgar Remote Support Client from Linux for support from Product Support Services
Building Operation Edge Server - Standard
Bomgar session downloads Bomgar-scc-[long string of characters].desktop file and need to run to connect with a Product Support Services agent.
The file needs to be granted permission to execute and then run.
  1. Open browser on Linux OS for website: https://seconnect.se.com
  2. Enter the 7-digit Session Key and press SUBMIT button.
  3. After saving the client to the Downloads folder, right-click on the bomgar-scc-[long string of characters].desktop file, then click Properties. Step1.png
  4. Click on the Permissions tab, then check the checkbox next to Execute to Allow executing file as program. Step2.png
  5. Open Terminal, then type "sh " (without quotes and not forgetting a space), then drag the file to the Terminal window, then press Enter. The full command will look similar to this image. Step3.png
  6. Once the executable runs, this image will appear on the screen as the full session begins. Step4.png
  • DavidPurser23
