Rounding off a number is called Loss of Significance - IEEE 754
  • Rounding off a number is called Loss of Significance - IEEE 754
  • PeterEdvik
    PeterEdvik
  • DavidChild
    DavidChild
  • Dave_Shore
    Dave_Shore
  • sesa139513
    sesa139513
  • Benji
    Benji
‎2018-09-06 11:54 AM
Last Updated: Janeway PeterEdvik Janeway ‎2022-07-14 03:56 AM
Numbers are rounded.
Why two values of nearly equal magnitude are subtracted, significant digits are lost.
This occurs in a variety of places within EcoStruxure Buildings Operation, and explained using a script program in the example below.
Ecostruxure Building Operation
  • Building Operation Automation Server
In a string program and the NumToStr function, if a number (example 5.7) is entered and Save is selected, then the Value in the Variables window at the bottom shows 5.6999998. The value is altered from the original.
When looking at a value in the watch window or variables view, there is no rounding so you are going to see the full length of the float number which suffers from a thing called “loss of significance”
More information on float numbers can be found at: https://en.wikipedia.org/wiki/Loss_of_significance This phenomenon happens everywhere.
An alternative would be to add a formatting feature to do the rounding.
Script handles numbers as IEEE754 single precision floats, so the accuracy is limited to (IIRC) seven significant digits.
The accuracy loss starts around 1.677E7.
On www.binaryconvert.com/convert_float.html?decimal site, a decimal number can be converted to binary and then back to decimal in order to see how the decimal number will be handled in Script.
On this site you can convert a decimal number to binary and then back to decimal in order to see how the decimal number will be handled in Script. http://www.binaryconvert.com/convert_float.html?decimal
Tags (4)
  • 11165
  • DavidChild20
  • DavidShore22
  • PeterLarsen25
