RoamIO Service Tool and physical access control objects.
  • RoamIO Service Tool and physical access control objects.
  • AbeMeran
    AbeMeran
‎2018-09-06 12:43 PM
Can the RoamIO service tool be used to view/edit physical access control objects (personnel, areas, doors)
RoamIO
RoamIO documentation
The RoamIO service tool does not support working with physical access control objects.
Door, personnel and area objects in the controller are not exposed to the service tool.
  • 7237
