Restoring a NL220 Backup might "Wipe out" some data on your hard drive.
  • Restoring a NL220 Backup might "Wipe out" some data on your hard drive.
  • MathiasBj
    MathiasBj
‎2018-09-06 02:47 PM
  • NL220
  • Vista
When restoring or creating a new database in NL220, files can be overwritten.
When restoring a database in NL220 you need to be aware of that any existing files and subfolders in the path specified as "Project's path" will be deleted. Always make sure to specify a folder that is empty or that does not contains any files you don't want to lose.
  • 3079
