Process to restore MNB-1000 to factory default.
TAC IA Series
MNB-1000
Warning
If the IP address has been lost or unit has been misconfigured how can this be restored the factory default.
*This step should only be taken if the data on the unit is not to be maintained *
- On the DIP switch settings, set all of the switches (1-8) to the ON position.
- Cycle power on the controller.
- Unit will boot up in reset mode (red flashing status light)
- Once completed the status light will be solid green.
The unit is now in factory default mode
The IP address will be 10.1.10.2 with a 255.255.255.0 subnet mask.
BACnet IP will be disabled by default and BACnet Ethernet will be active.
