Resolving "0/1 Nodes Available: 1 Too Many Pods" Error in PCT2 When Starting EBO Virtual Servers
  • Resolving "0/1 Nodes Available: 1 Too Many Pods" Error in PCT2 When Starting EBO Virtual Servers
  • Mahmoud_Sayed
    Mahmoud_Sayed
Kirk Mahmoud_Sayed Kirk
‎2024-08-20 07:24 PM
on ‎2024-08-20 07:24 PM
When trying to run an EBO virtual server in PCT2 the following error message is received:
Server failed with reason 'unschedulable, 0/1 nodes are available: 1 Too many pods. preemption: 0/1 nodes are available: 1 No preemption victims found for incoming pod..'. Go to diagnostics page for more information.
Server failed with reason 'unschedulable, 0/1 nodes are available: 1 Too many pods.  preemption: 0/1 nodes are available:  1 No preemption victims found for  incoming pod..'. Go to diagnostics page for more information.Server failed with reason 'unschedulable, 0/1 nodes are available: 1 Too many pods. preemption: 0/1 nodes are available: 1 No preemption victims found for incoming pod..'. Go to diagnostics page for more information.
Building Operation Project Configuration Tool (PCT)
The maximum number of running servers in PCT 2 has been exceeded.
PCT 2 supports a maximum of 250 running servers. If this limit is reached with 250 servers already operational, no additional servers can be started.
  • MahmoudSayed24
