Required Modbus driver for Niagara R2 UNC to support Modbus RTU RS-485
  • Required Modbus driver for Niagara R2 UNC to support Modbus RTU RS-485
  • sesa119747
    sesa119747
  • sesa116871
    sesa116871
‎2018-09-06 02:56 PM
Last Updated: Administrator DavidFisher Administrator ‎2019-10-07 08:17 AM
Which Modbus driver is required for a Niagara R2 UNC to support Modbus RTU RS-485?
TAC IA Series
  • Niagara R2 UNC
  • Modbus RTU RS-485
The correct Modbus driver must be installed to allow communication between Niagara R2 and Modbus RTU RS-485.
The Modbus drivers can be installed on the UNC-510-1 and UNC-520-2 models with a maximum supported baud rate of 19.2k for the UNC-510 and 76.8k for the UNC-520.
The part numbers are:
  • IA-DRV-MOD (master)
  • IA-DRV-MOD-S (slave)
  • TAC IA Series
  • 2699
