Required EPROMs for Door Processor Units (DPUs) in I/NET Seven for use with 26-bit Wiegand Pin Pad Customized Pin feature
  • Required EPROMs for Door Processor Units (DPUs) in I/NET Seven for use with 26-bit Wiegand Pin Pad Customized Pin feature
  • sesa139513
    sesa139513
‎2018-09-06 03:25 PM
I/NET site
What EPROMs for Door Processor Units (DPUs) in I/NET Seven must be used for 26-bit Wiegand Pin Pad Customized Pin feature?
3.00 (or greater) is required in a DPU to get this feature.
  • TAC INET
  • 1150
