Replacing one vendors access card reader with a different vendors card reader
  • Replacing one vendors access card reader with a different vendors card reader
  • Carl_Slack
    Carl_Slack
‎2018-09-06 02:18 PM
Is one access vendors card with Wiegand 26 bit output the same as another vendors Wiegand 26 bit output?
Continuum 1.xx
Access Control
Replacing access card reader.
When replacing access readers follow the manufacturer’s installation instructions for that particular reader. Wiegand 26 bit output type is a standard so that output will be the same.
  • 4303
