Replacing actuator M44PBB on valve STM-G
  • Replacing actuator M44PBB on valve STM-G
  • SESA150559
    SESA150559
‎2018-09-06 12:14 PM
Both valve and actuator in question are obsolete. In this case the valve is still OK, while the actuator is in need of replacement.
M44
STM-G
M9B/24 8601010000
mounting kit 8600990000
Replacement of obsolete actuator
M9B/24 (8601010000) together with mounting kit 8600990000 will replace the M44PBB when used on STM-G. The only feature missing would be the potentiometer.
  • Field Devices
  • 8159
