Replacing a M15 actuator when mounted to a VTRA.
  • Replacing a M15 actuator when mounted to a VTRA.
  • SESA150559
    SESA150559
‎2018-09-06 01:05 PM
Which actuator should be used as replacement to a M15 actuator that is mounted on a VTRA Valve?
VTRA DN65
M15 24V / 12VA 15 Nm 300s / 180°
Currently used actuator is no longer available.
Use EM9/180 (part no 8601110000) together with Linkage kit E/M9-VTRA (part no 8600990000).
  • Field Devices
  • 6569
