Replacing a M15 actuator when mounted to a TRV
  • Replacing a M15 actuator when mounted to a TRV
  • SESA150559
    SESA150559
‎2018-09-06 10:26 AM
Which actuator should be used as replacement to a M15 230V actuator that is mounted on a TRV Valve?
M15
TRV
M9B
Currently used actuator is no longer available.
Use M9B/230 (part no 8601020000) together with Linkage/mounting kit for Butterfly valve TRV, Item Number: 8600991000
  • Field Devices
  • 13159
