Replacing VEX, MEX, FEX valves and AVX, AVM actuators
  • Replacing VEX, MEX, FEX valves and AVX, AVM actuators
  • sesa139513
    sesa139513
  • DavidChild
    DavidChild
‎2018-09-11 06:12 AM
Thermic Valves
The valve and / or actuator requires replacement.
The AVX and AVM are a 2 wire thermic valve actuator, its stroke length is 2.5mm short stroke. The valve actuator fitting is an industry standard 30mm x 1.5mm thread.
To replace the valve use the VZ208 (2 port), VZ308 (3 port), VZ408 (4 port).
To replace the actuator use either the MZ140-24T (24Vac) or the MZ140-230T (230Vac).
Download the VEX, MEX, FEX, AVX, AVM datasheet here.
Download the VZ208, VZ308, VZ408, MZ140 datasheet here.
  • Field Devices
  • 14515
