Replacing M750
  • Replacing M750
  • SESA150559
    SESA150559
Replacing M750
‎2018-09-06 12:48 PM
Which actuator is suitable to replace the Forta M750 actuator?
Forta M750
Forta M800
Since the Forta M750 is no longer available, it needs to be replaced by a suitable actuator.
The Forta M750 should be replaced by the Forta M800 actuator.
  • Field Devices
  • 7091
