Replacing EM42 actuator on VTRA valve
  • Replacing EM42 actuator on VTRA valve
  • SESA150559
    SESA150559
‎2018-09-06 11:09 AM
EM42 is obsolete and is no longer available when replacement is needed
VTRA linkage kit 8600990000
EM9 180° 8601110000
VTRA valve
EM42
Replacement of obsolete actuator on old style valve
The replacement actuator for EM42 on a VTRA valve is  EM9 180°, 8601110000, together with linkage kit 8600990000. The linkage kit originally included with the EM9 package should NOT be used.
  • Field Devices
  • 11058
100% helpful (1/1)
