Replacing AR? for MD20-24 actuator to fit MB/MBF valve.
  • Replacing AR? for MD20-24 actuator to fit MB/MBF valve.
  • Gary
    Gary
‎2018-09-06 01:22 PM
When changing an ARM/X/E type actuator that was mounted on an MB or MBF valve a new linkage kit is required.
  • Valve
  • MB
  • MBX
  • MBF
  • ARE
  • ARX
  • ARM
  • Linkage
  • Actuator
  • MD
When fitting a new stype actuator to an MB/MF valve a new linkage kit is required.
MD20a/b Linkage kits
MB-914-1071-000
MBF-914-1070-000
(Use self tappers that came with the act to fix the linkage)
If you have auxiliary switches you will also need to purchase the aux SW kit for the MD10/20 b = MD-S2
Click here to view the data sheet for the MD20 B actuator, where you will find further information.
  • Field Devices
  • 6189
