Replacement valve for V384
  • Replacement valve for V384
  • DavidChild
    DavidChild
  • Dave_Shore
    Dave_Shore
  • SESA150559
    SESA150559
‎2018-09-06 11:04 AM
Last Updated: Sisko DavidChild Sisko ‎2021-03-31 05:26 AM
Valve V384 is obsolete, a replacement valve is requested.
Field Devices
V384
7318421000
7318425000
7318429000
7318433000
7318437000
7318441000
7318445000
7318449000
V341
7314121000
7314125000
7314129000
7314133000
7314137000
7314141000
7314145000
7314149000
V311T
7311717000
7311721000
7311725000
7311729000
7311733000
7311737000
7311741000
7311745000
Replacing obsolete valve V384
Depending on application, the V311T(nodular iron) or V341(bronze) are recommended as replacement valves. Both will require pipework modification and for V341 a connection kit will be required if internal threads are necessary.
  • Field Devices
  • 11251
