Replacement part for TSS100WJ and S/STAT
  • Replacement part for TSS100WJ and S/STAT
  • DavidChild
    DavidChild
  • Sacco
    Sacco
‎2018-09-10 04:57 AM
The STR-200 and STR-202 are the recommended replacement for TSS100WJ and S/STAT.
  • STR-200
  • STR-202
  • Xenta 102-AX
  • 7728
  • MR-VAV
  • TSS100WJ
  • S/STAT
Obsolete parts
STR200 replaces the TTS100WJ (Temperature Sensor Only, PN)
STR202 replaces the S/STAT (Bypass button and Offset wheel)
STR200-202 can be used with the 7728, MRs, and Xenta 102-AX controllers.
STR200 . . . . . . . . . . . . . . . . . . . . . . . . 004603000
STR200-W (White) . . . . . . . . . . . . . . . . 004603010
STR202 . . . . . . . . . . . . . . . . . . . . . . . . 004603200
Full Datasheet containing additional information is located here.
Tags (4)
  • 6684
  • David Child19
  • DavidChild19
  • thermostat
