Replacement part for RYB-922-11 repair kit
  • Replacement part for RYB-922-11 repair kit
  • HenrikTarpgaard
    HenrikTarpgaard
‎2018-09-06 09:22 AM
 RYB-922-11 is no longer available and needs to be replaced
RYB-922-11
Repair Kit for VB-922x-0-4-11
repair kit no longer available
There is no replacement for this kit. The customer will have to replace the valve body which probably will be the VB-7223-0-4-11 but verify which valve the customer has. Also since this new valve has a different stroke the customer will need to replace the actuator and linkage kit to ones that are used on the VB-7000 series valves.
  • Field Devices
  • 16927
