Replacement of an MF-63123 actuator.
  • Replacement of an MF-63123 actuator.
‎2018-09-11 04:37 AM
Last Updated: Crewman ContentModerator ‎2025-08-11 03:50 AM
What actuator can be used as a replacement for the MF-63123?
MF-631x3 Series_F_24732_8.pdf (209 KB)
MFC 8000_F_25124_4.pdf (260 KB)
Field Devices
  • MF-63123
Original actuator has failed, or requirement for a non US actuator.
Using the installed valve details, the actuator can be selected from the Schneider Electric Valve and Actuator selection Tool.
  • Field Devices
Tags (2)
  • 13983
  • DavidKendrick22
0% helpful (0/1)
