Replacement of VTR Valve Body by VTRE or MB/MBF Valve Body due to obsolescence.
  • Replacement of VTR Valve Body by VTRE or MB/MBF Valve Body due to obsolescence.
  • DavidChild
    DavidChild
‎2018-09-10 05:45 AM
Last Updated: Sisko DavidChild Sisko ‎2022-03-03 08:38 AM
VTR Valve Body requires replacement due to obsolescence.
Field Devices
  • VTR
  • VTRE
  • MB
  • MBF
Obsolescence of VTR Valve Body.
VTR Valve Bodies are obsolete and have been for many years.
VTR Valve Bodies were available with either Flanged or Screwed connections.
REPLACEMENT OF VTR FLANGED CONNECTION VALVE BODY
A replacement for the VTR Flanged Valve Body (20-150mm only) may be selected from the VTRE range of flanged valve bodies,
N.B.
It should be noted that the VTRE Valve Body is rated PN6 whereas the VTR was rated PN10.
The VTRE Flanged Valve Body may be operated by the EM9 Actuator.
Alternatively the VTRE Flanged Valve Body may be operated by the M9B actuator.
No Linkage Kit is required to mount the EM9 or M9B Actuator on the VTRE Flanged Valve Body.
Alternatively a replacement for the VTR Flanged Valve Body (65-100mm only) may be selected from the MBF range of Flanged Valve Bodies.
N.B.
It should be noted that the MBF Valve Body is rated PN6 whereas the VTR was rated PN10.
The MBF Flanged Valve Body may be operated by the MD20B series actuator.
Alternatively the MBF Flanged Valve Body may be operated by the MD20A actuator.
A Linkage Kit (914-1070-000) will also be required.
REPLACEMENT OF VTR SCREWED CONNECTION VALVE BODY
A replacement for the VTR Screwed Valve Body (15-50mm) may be selected from the MB range of screwed valve bodies.
The MB Screwed Valve Body may be operated by the MD10B series actuator.
Alternatively the MB Screwed Valve Body may be operated by the MD10A actuator.
A Linkage Kit (914-1071-000) will also be required.
The datasheets concerning all the above options are available for download.
  • Field Devices
VTR.zip
Tags (2)
  • 6963
  • DavidChild22
